-AndyH-
Expert
Message 31 of 36
Re: World of Warcraft latency?
Is there some kind of add on that allows you to see your CPU/memory usage?
jarsc
Message 32 of 36
I have Arx control, a part of Logitechs software, it links my system with an android or I phone. there's a section that shows me Gpu, cpu & memory usage.
 cpu was at around 20%, memory 35% and GPU around 50-70%!
 The funny thing is, I got disconnected from wow and my Arx control lost connection to the network. I logged back into WoW and my ms on the Addon Quartz was showing 30-40 ms. This hasn't happened for agaes, the game was smooth and I will now have my fingers crossed, until something changes!
craigst
Message 33 of 36
whats ping in the game if u can get it up and fps
was the issue after a patch ?
i have same issue with eve online server only lasted a couple of days as a go daddy server was droping the root connection
you could try useing a vpn nearer the wow server (europe/usa) depending what your one , if vpn works could be firewall / route issue
turn off firewalls and give it a try or add your pc to the dmz keeping you pc firewall on if you want
im taking a whiled guess your using wifi , if so can easy be a wifi issue u could try eathernet over power adapter or using 5ghz connection
hope that helps u fault find
hope you get it sorted
jarsc
Message 34 of 36
I'm on etherenet, directly liked to the router.
 Been monitoring it, it seems when I shift server, as in Blizzard have different servers pertaining to what your doing, it seems to fluctuate. Just sitting in my Garrison I'm ok as in I'm casting at about 40ms-50-ms even though the actual game tells me I'm at 25ms. Yet if I move to a town like Stormshield I cast at about 150ms, with the game still showing 25ms. When I enter a raid I'm casting at about 250ms- 400ms, with the game showing  me 25ms still.
 Very cofused!
craigst
Message 35 of 36
ok to internal server switch , u on europe or us ?
i think only think u can test is a vpn for now try wifi just if faulty ethernet cable , unlikley but cant rule it out
jarsc
Message 36 of 36
I'm on Aggramar EU.
 Tried a brand new Ethernet cable, same results!
