Alansmithee
Message 1 of 6
Worth downgrading to infinity 1
With infinity 1 now being switched to 52meg and the fact that I have never seen over 40meg on my connection - is there a good reason not to simply downgrade to infinity 1?
5 REPLIES 5
imjolly
Message 2 of 6
Re: Worth downgrading to infinity 1
If you have a hh5 post the stats from troubleshooting then helpdesk. However if best speed you get is 40mb then you should have downgraded ages ago to infinity 1 and with recent increase in infinity 1 to 55/10mb then you will get same speed as present
gg30340
Message 3 of 6
If you have never had above 40Mbps you should have downgraded long before now. You have been wasting your money on Infinity 2.
Alansmithee
Message 4 of 6
I don't use the HH5 which I found to be junk - I have a  hg612 used with a asus rt-ac68u.
What is the quickest way for me to get stats?
imjolly
Message 5 of 6
The stats are in the modem unless it is unlocked
run checker and post results remember delete number https://www.btwholesale.com/includes/adsl/main.html
licquorice
Message 6 of 6
Unlocking the HG612 to get the stats is pretty trivial.
