rjhsteel2001
Message 1 of 3
Worth upgrading Router?
I have a BT Hub 4. Will upgrading the router increase the performance? If so, what should I upgrade to?
2 REPLIES 2
john46
Message 2 of 3
Re: Worth upgrading Router?
If it is working ok then leave it alone
N0STIE
Message 3 of 3
I would upgrade it to 3rd party router if I was you, or just purchase an Openreach modem as HH is unreliable especially if you have infinity connection. Random HH restarts "helps" you to get into DLM 🙂
