How can I extend the length of time for an incoming call ring period?
Solved! Go to Solution.
Access the Menu using the Menu button, at which point ANSWER MACHINE should be displayed - press the Menu / Tick button.
Scroll down (Redial Button) until TAM SETTINGS is displayed - press the Menu / Tick button.
Scroll down (Redial Button) until ANSWER DELAY is displayed - press the Menu / Tick button.
Scroll up (Calls Button) or down (Redial Button) until the number of rings you wish to have before the Answer Machine picks up the call is displayed - press the Menu / Tick button.
