Message 1 of 4
Xbox 1 Port forwarding
Hi,
I have an Xbox 1s which keeps disconnecting from the smart hub through wired connection.
I have been told to set up port forwarding on the smart hub for the Xbox. I have opened the router webpage and tried to open the ports. Does anybody know which internal and external ports I need to open where it says start and end ports ?
Thanks in advance.
3 REPLIES 3
Message 2 of 4
Re: Xbox 1 Port forwarding
Hi @chadders1 Check out How do I set up port forwarding on my BT Hub?   and see if that helps you.
Cheers
John
Message 3 of 4
Thanks for the reply.
I can get that far but cannot seem to find what ports I need to open for an Xbox 1.
Do you have any ideas ?
Message 4 of 4
Hi @chadders1 Check out Network ports used by Xbox Live on Xbox One on the Xbox support website and that should help.
Cheers
John
