alekssrb1
Message 1 of 31
Xbox Live keeps disconnecting- Please help!
I have had this problem as soon as I joined a few weeks back.It didnt happen with virgin media. I connect via wireless to the home hub and it varies but usually every 10/20 minutes it disconnects and I can connect back straightaway. I have a feeling that it is a problem with the wiring. Can anyone help me, especially Bt people? This may happen on the laptop too when I use a constant connection because sometimes when I am watching a video on youtube it stops to buffer half way through but this may not be relevant.
30 REPLIES 30
john46
Message 2 of 31
Re: Xbox Live keeps disconnecting- Please help!
for reliable gaming you really need a wired connection
alekssrb1
Message 3 of 31
but it worked before no problems its reliable too before it disconnects so wired connection is the same
Keith_Beddoe
Message 4 of 31
My guess is that you are using a home hub 3, and it is renewing the DHCP lease every 20 minutes, that is why it is dropping the connection.
To overcome this problem see Static IP with Home Hub
Instructions for the Xbox are here http://portforward.com/networking/staticip-xbox360.htm
alekssrb1
Message 5 of 31
I dont think it is the solution as the time it disconnects varies usualy 10-20 mins but I will try to do that
Keith_Beddoe
Message 6 of 31
@alekssrb1 wrote:
I dont think it is the solution as the time it disconnects varies usualy 10-20 mins but I will try to do that.
I think you will find that the lease time does vary, depending on the number of connections.
People on the Xbox forums always recommend using static addresses, especially if port forwarding is used.
Keith_Beddoe
Message 7 of 31
Also read these threads
http://community.bt.com/t5/forums/searchpage/tab/message?filter=location&location=Board%3ABBinHome&q...
You can see the home hub logs, and you could look at your own to see for yourself
alekssrb1
Message 8 of 31
thanks it seems to be working i will reply if it doesnt
alekssrb1
Message 9 of 31
it didnt work just disconnected after 2 hrs
john46
Message 10 of 31
It could also be wireless interference have you tried changing channels
