Keith_Beddoe
Message 11 of 31
Re: Xbox Live keeps disconnecting- Please help!
@alekssrb1 wrote:
it didnt work just disconnected after 2 hrs
That would be just be wireless issues, you need to use a cable connection for gaming. Wireless is not reliable enough, and will disconnect if there is interference.
If you cannot run a cable, then use powerline adapters.
alekssrb1
Message 12 of 31
I've tried many  times none worked
alekssrb1
Message 13 of 31
but if it worked before with virgin how does it suddenly do it now. Wireless was never a problem before!
Keith_Beddoe
Message 14 of 31
All wireless routers behave differently due to different chipsets inside. Have you still got your old router?
alekssrb1
Message 15 of 31
yes i have it
Keith_Beddoe
Message 16 of 31
@alekssrb1 wrote:
yes i have it
What make and model is it?
alekssrb1
Message 17 of 31
D-Link DIR-301
Keith_Beddoe
Message 18 of 31
@alekssrb1 wrote:
D-Link DIR-301
That is a cable router, so you would not be able to use it on a BT line, however you could use the wireless
part of it, instead of using the BT Home hub wireless, that may solve your problem, as its a wireless issue.
I will look at the manual for you, and suggest the best way to do it.
Keith_Beddoe
Message 19 of 31
Section 2 of the manual tells you how to use it purely as a wireless access point.
You must however change the IP address of the device, as its in the wrong subnet.
I would suggest that you change it to 192.168.1.15.
Once you have done that, you simply connect it to one of the HH2 Ethernet ports, and turn the HH2 wireless off.
You should then be using your old wireless router as an access point.
If you have not got a full manual, then let me know.
alekssrb1
Message 20 of 31
I do that and I get limited or no internet access?
