magpie03
Expert
Message 1 of 3
Xbox Live
Hi all wondering if I could get any help here, I have been using BTWiFi as I'm during a house move and internet is offline for a while. I have a ethernet cable from laptop to Xbox sharing the connection so I can get online. I can get online fine the only issues is that the connection is a strict nat, I thought I had managed to open ports via the network connection on my laptop but it doesn't seem to work. Is there anything else I can do to help the connection?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Xbox Live
Hi
If you are using a BT Wifi hotspot you will not be able to change any settings on the hot spot.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Malacath
Expert
Message 3 of 3
Re: Xbox Live
I had the same problem when using my xbox on BT wifi hotspot The NAT on wifi hotspot goes strict after a while and the only way to open the NAT again is to reset the home hub that is broadcasting the hotspot.
Obviously this is not possible if you don't own the hub
