Message 1 of 6
Xbox device on wifi not seen on BT hub manager. want to set BT access control to stop wifi
Xbox device on wifi not seen on BT hub manager even though it is in use and working.  I need to set BT access control to stop wifi at a set time.
5 REPLIES 5
Message 2 of 6
Re: Xbox device on wifi not seen on BT hub manager. want to set BT access control to stop wifi
Whuch hub version ?
Have you clicked on refresh, to update the list ?
Message 3 of 6
Message 4 of 6
When it was connected to a BT Broadband extender plug the Xbox could be seen. Now it’s using WiFi it’s not available.
Message 5 of 6
I suspect that the home hub has not updated its configuration to reflect the new method of connection. This is quite a common issue with the home hubs.
Try a factory reset of the home hub.
http://bt.custhelp.com/app/answers/detail/a_id/11386/%7E/how-do-i-reset-my-bt-hub-to-its-factory-set...
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Message 6 of 6
Thanks, that worked perfectly
