Message 21 of 22
Re: Yet another poor sod with slow broadband...
Have managed to extract result from BT Speedtester site now, all looks a lot healthier!
FAQ
Results Image not loaded
<script type="text/javascript">// paintProgressAndMessageOnBar(100,"The test has successfully completed" ); // </script> Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
11749 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 11749 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :17927 Kbps(DOWN-STREAM), 1199 Kbps(UP-STREAM)
 IP Profile for your line is - 15000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 6.84:20.43:72.73 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
715 Kbps
0 Kbps1199 Kbps
>Upload speed achieved during the test was - 715 Kbps
 Upstream Rate IP profile on your line is - 1199 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Message 22 of 22
Final post hopefully...stable for over 24 hours now and 13mb download and 1mb upload...quite satisfied with that!
Thanks and cheerio...Smiley Happy
