richardpolhill
Message 1 of 11
Yet another poor speed question.
I used to get something around 58Mbps on my 80Mbps line but something went wrong around July/August and I've not got anything as good as that since:
I'm wondering if my DSL settings are correct on my modem (Asus DSL-N66U) or if there is a problem on the copper to my house. Anyone able to advise?
10 REPLIES 10
imjolly
Message 2 of 11
Re: Yet another poor speed question.
can you enter your phone number and post results  remember to delete number but leave exchange and cab  https://www.btwholesale.com/includes/adsl/main.html
run btspeedtster and when first test completes then run diagnostic test and post results  must be done with wired connection
btspeedtester
check quiet line test  dila 17070 option 2  should be quiet and best with corded phone
richardpolhill
Message 3 of 11
Thanks. It'll have to wait until I can get my hands on a phone to plug in.
pompey1898
Recognised Expert
Message 4 of 11
Have you tried enabling G.INP ?  See here :- http://www.increasebroadbandspeed.co.uk/g.inp
imjolly
Message 5 of 11
please for your security delete your phone number
as you are on Huawei cab then I would enable G.INP as suggested
richardpolhill
Message 6 of 11
Ah thanks.
richardpolhill
Message 7 of 11
Interesting. That looks like it's improved things a chunk. Looks like 52Mbps now. Thank you.
Presumably the line will eventually resync at a higher speed and I'll get back closer to 58kbps eventually?
richardpolhill
Message 8 of 11
Is there any way of categorically knowing which other DSL settings I should set for this line?
ANNEX? DLA? Stability Adjustment? Tx Power Control? UPBO? SRA? Share PVC? VDSL Profile or 30a or 17a?
Thanks in advance.
imjolly
Message 9 of 11
you currently now have a connection speed of 52mb with an attainable of 56mb with noise margin of 5.7db so from that I can't see where you will get more speed
you are within estimate although at bottom end
richardpolhill
Message 10 of 11
Thank you.
I could try replacing the (5m) cable between the wall point and the router which might reduce soem of that noise.
But thanks for your help.
Rich
