user1979
Message 1 of 3
YouView BTV-448
Hello,
We recently moved home and it took ages to get the phone line and broadband reconnected. Now, whenever we load the BT TV player on YouView it has the following message:
Something's gone wrong
Sorry, we can't make this work at the moment. Please try again later. [BTV-448]
I've tried the usual "turning it off and on again" but nothing I've done makes any difference.
Any idea what this message means and how I can fix it?
Chris
2 REPLIES 2
pwwhitehead
Message 2 of 3
Re: YouView BTV-448
There are the details for your error message:
115, 127, 128, 130, 131, 132, 133, 134, 137, 139, 143, 144, 153, 154, 155, 156, 157, 164, 165, 166, 167, 168, 315, 316, 317, 318, 320, 326, 327, 333, 334, 336, 411, 414, 416, 417, 419, 420, 426, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 448, 501, 511, 512, 513, 515, 516, 517, 1101, 1102, 1103, 1104, 1105, 1106, 1107, 1108, 1109, 4017
Follow these steps to try and fix these BTV errors:
Try to access the BT player. Press the YouView button then scroll to and select the BT icon
If you still see the error message then try restarting your equipment by following these steps:
First, restart your BT Home Hub
Wait for the broadband light on your Hub to go blue
Restart your YouView box, using the power switch on the back of the box
Now check if you still receive the error
Check your software version is up to date. To do this go to Settings > Device Management > Software Update and press OK
Check your On Demand players are up to date. To do this go to Settings > Device Management > Update On Demand Players and press OK
user1979
Message 3 of 3
Re: YouView BTV-448
I received a SMS from Lyndsey saying she is going to forward details to the relevant department.
Just in from work and checked it - I'm pleased to say that it is now working.
Chris
