Message 1 of 4
YouView Box power supply broken
Youview Box not working so had a look, moved plug and the cable is loose and began sparking - dangerous! Are BT kind enough to send a replacement? Especially as I've just spent £130 on an engineer coming out for something else!
3 REPLIES 3
Message 2 of 4
Re: YouView Box power supply broken
@jenni2jenni
BT would want to send a replacement box, and you would have to send the existing one back in the returns box provided, however you may be able to locate a replacement online, as they are very common.
You would have to still be in a BT TV contract to get a replacement loaned box.
I assume you are paying out £130  for an internal master socket move?
Message 3 of 4
Happy to receive a new box. I'll have to get in touch with them and see if they oblige. Thank you.
Message 4 of 4
You may also want to look into why it broke in the first place if it could be something to do with your home environment.
