mrjcotterill
Message 1 of 11
YouView Connection via Switch?
I am thinking of getting YouView but I would want to connect my new youview box to my gigabit switch which is in turn connected to my HH4 gigabit port. Will this work?
10 REPLIES 10
Distinguished Guru
Message 2 of 11
Re: YouView Connection via Switch?
Hi
This is how I run my set up with no problems.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
mrjcotterill
Message 3 of 11
Thanks. Good to know. Do you get the extra 18 channels with Infinity as well and the sport do they work too?
cactusbob
Message 4 of 11
Don't know about the extra channels as BT havent managed to get mine working yet. The multicast sports channels are working fine for me through a gigabit switch though.
mrjcotterill
Message 5 of 11
Great thanks. What switch do you use? How come BT haven't got your extra channels working yet?
Distinguished Guru
Message 6 of 11
Yes 🙂
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
cactusbob
Message 7 of 11
I use a Netgear JGS524E. As for the extra channels - that's a very long story
mrjcotterill
Message 8 of 11
Oh dear... Lets hope I don't have the same issue then! Box due on Tuesday. I ordered this morning based on this thread and much other research suggesting it will all work with the set up I have.
davidb00
Message 9 of 11
I have not heard of any problems using a cat 5 cable & a switch, I use a cheapo TP- Link 10/100 kbs switch connected to a HH3 and have driven 2 HD iplayer channels(1 Youview & 1 on my Panny bluray) simultaneously, with no problems.Smiley Happy
cactusbob
Message 10 of 11
My extra channels started working today, they also work fine through my switch
