Hi i'm curious to know if anyone has the YouView+ Ultra HD Total Entertainment Package With Multiroom? I wanted this package with just a basic YouView box in another room (thru the wall).
After 5 weeks of going back and forth BT now tell me i cant have this setup and need to reduce my package from Total Entertainment to Entertainment Plus.
I'd be interested to know if anyone has this setup i require and how you got it? Also the engineer installing the main box said an additional box wouldnt be a problem.
Thank you!
@davido77 Welcome to the forum and thanks for posting, I'm sorry about the delay getting back to you. Yes it is possible to have a second Youview box subscription in addition to your Ultra HD service however this is dependant on your broadband speed and our systems won't accept an order for the second Youview box if your connection is too slow.
What's your line speed?
If it's not sufficent you're going to be able to order it. The 'engineer' is actually an installer and probably has no idea what the speed requirements are.
Speed requirement for UHD and extra box is 54Mbps but the wholesale checker needs to state you can get that...
https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
I could be wrong but I think it is the Clean low they look at and that needs to be above 54Mbps to be able to order Total Entertainment with Extra box...
Sounds like an upgrade to Infinity 2 would sort the issue.
Maybe you could get some deal from BT for the hassle you've had? Worth asking them?
@4KMarty wrote:Sounds like an upgrade to Infinity 2 would sort the issue.
If you have the Ultra HD package with Infinity 1 then for BT TV you actually get Infinity 2 speeds - where available - for BT TV only. At least that's my experience.
