SeanD
Community Manager
Community Manager
Message 1 of 6
YouView software release 22.18.0
Hi Everyone
Just a heads up that BT will be rolling out the latest YouView software update, 22.18.0 to all BT YouView customers.
There are no new features included in the latest release just some stability improvements.
Cheers
Sean
5 REPLIES 5
billat29
Message 2 of 6
Re: YouView software release 22.18.0
22.18.0 breaks CEC. Other boxes connected to my TV no longer send commands to each other. Problem solved if HDMI cable to youview box is removed (swapping cables has no effect).
Is there a way to revert to a release that works?
Michelle_
Message 3 of 6
Bt TV. Box updated itself last night. Woke up to a red light on my box. So I've turned on and now there no volume at all in my tv.
I've closed it down. Turned on turned off. Nothing works. Anyone else had the same problem?
skappy70
Recognised Expert
Message 4 of 6
I occasionally have this issue, it was there before the latest update, remove the HDMI cable from the YV box for 10 secs. sound should come back.
Michelle_
Message 5 of 6
Thanks very much. It worked !! 😀
ney
Expert
Message 6 of 6
Just got the update on both boxes after I did a manual update. All seems ok so for.
I have the older style BT Youview box that I now just use as a Freeview PVR and for the free catch up players.
I use the G4 box for BT TV and Freeview.
Darren
