Paulbish
Message 1 of 1
Youview Apps keep loosing connection
Hey all, I'm using BT WIFI extenders and unless the Youview box is directly plugged into the box the apps constatnly loose connection. iPlayer seems to be the worse, nextflix constantly gets stuck at 25%.... It's only the apps which do this... BT player and the internet channels like Sky Sports still work fine..
I get around 70mb download, the extender works on my amazong box & apple TV. It's only the APPs on the Youview box this is happening it. It's extrememly annoying!
Any suggestios or anyone else have this problem?
