Message 1 of 13
Youview G4, sound no picture
Just got the latest G4 youview box and works ok. But whenever the box boots up from cold I get no picture, just sound.  There is signal going to the tv because if I press a number I see the number on the screen.  Once I change to a different channel I get the picture back.
Any ideas?
12 REPLIES 12
Expert
Message 2 of 13
Re: Youview G4, sound no picture
My new G4 did that on 2nd power-on yesterday - fine during install & setup ... left for a couple of hours and no pic on power-up ... unplugged & re-seated HDMI at TV end and OK ... hmmmm, will it happen again later ?
Message 3 of 13
is this a hardware or software issue...?
Message 4 of 13
hi, i get this happening as well, no picture when first switching on but then picture appears when i change channels
Expert
Message 5 of 13
New G4 box for you too ?
Is this a trend for a new batch shipping out in the last week or so ?
Message 6 of 13
yes new g4 box received last thursday
Message 7 of 13
I've had this issue several times. Switching off and switching back on again usually sorts it out.
Expert
Message 8 of 13
No recurrence yesterday evening ....
Message 9 of 13
My 2 weeks old box does this when i channel surf, at random, on a regular basis. Simple channel up and down fixes it though. At least i am not alone.
Distinguished Guru
Message 10 of 13
I've not used this box but the problems you are describing were all present on 17.3 on the original box. I expect it will be solved when the next software release comes along.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
