zulu17
Distinguished Guru
Distinguished Guru
Message 1 of 23
Youview - Retail Boxes Get January software update
Came across this
http://community.youview.com/youview/topics/automatic_software_update_january_2013
New software for the YouView Humax box is now available and will be rolled out across all Retail boxes over the next couple of weeks. This is a phased roll out so some boxes will get the update sooner than others. The software will be available on YouView boxes from BT and TalkTalk shortly afterwards.
22 REPLIES 22
TimSmedley
Message 2 of 23
Re: Youview - Retail Boxes Get January software update
This will solve a large number of the queries!
walkerx
Recognised Expert
Message 3 of 23
my retail box is updated to the latest version 🙂
no further need for the optical cable any more - will check some hd films tomorrow
flags
Message 4 of 23
My tv & youview box were having "handshaking" problems. The youview box would freeze anytime the box were switched on before the television ... no idea why ! It always seemed to happen at that point where the box recognised the tv as being in 1080p and not 720p. it just had a little panic attack and froze.
But *touch wood* this update seems to have cured that.
I really do love BT YouView.
bobjob
Message 5 of 23
Still have not had January update yet,is there a problem ??Anyone else not had there's
chrisp18
Message 6 of 23
Hi, as you are posting here I assume you, like me, have the BT supplied Humax.
If it's any consolation I haven't received the update yet either (I am on the Sudbury transmitter).
duncansby
Message 7 of 23
I have just received the update via a manual update. Can confirm that you can now search the guide which is handy
Rockintone
Message 8 of 23
Yep, manual update picked it up, downloading now.
bobjob
Message 9 of 23
Did a manual update tonight,and yes mine is through.
chrisp18
Message 10 of 23
You are all very fortunate.
I have just checked my box (07:30) and it has still not been updated and if I click the update button it just says software is the latest and last checked 22nd January.
Didn't think it was possible to apply manual update for the BT boxes so would be interested to know how you managed it.
