mccann
Message 1 of 3
Youview and Asus AC68U
Evening all,
Got my Youview box today and all set up.
Having some trouble getting my BT Sport to work and I've had a look through the forums here and tried the different solutions regarding 3rd party router setups.
I have tried the suggested settings below........
Choose IPTV STB Port: None
Use DHCP routes: Microsoft
Enable multicast routing (IGMP Proxy): Enable
Enable efficient multicast forwarding (IGMP Snooping): Enable
UDP Proxy (Udpxy): 0
I even followed the other suggestion of changing the DNS settings but still no joy.
When I use those settings my connect doesn't work at all even on phone or pc, there is no internet connection until I revert back.
I'm on the latest Asus firmware 3.0.0.4.378_9168-gaef80c4
Would be glad if someone could help me out or compare settings if using the same router.
2 REPLIES 2
mccann
Message 2 of 3
Re: Youview and Asus AC68U
Scrap that I got it sorted.
I turned off DHCP Server.
embattle
Message 3 of 3
So did you keep any of the original settings in your first post, what do you mean you turned of the DHCP server, how are you then organising the other devices...are you manually assigning IPs?
