Message 1 of 6
Youview app failing
Hi there, I'm having some problems with the youview app. Bookings are failing immediately despite there being 60% space and no other bookings scheduled. I've disconnected and reconnected the device and re installed the app, but still no luck. Can you help? Thanks!
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: Youview app failing
What standby mode is your Youview box in ?
Try setting up a recording via the app whilst you are at home and your Youview box is on  - does that recording get set up OK?
Message 3 of 6
Hi there thanks for the reply, no its really strange not even when it's on and I'm using the same wireless it still fails within minutes. It initially worked fine too
Distinguished Guru
Distinguished Guru
Message 4 of 6
I suggest raising with Youview -
https://community.youview.com/youview
their experts (normally around Mon-Friday) should be able to advise if they have seen reports of similar problems and suggest how to proceed.
Recognised Expert
Message 5 of 6
Have you tried a soft reboot of the Youview box or just powering it down for a few minutes? Those processes can often restore normal use.
Message 6 of 6
thanks everyone! soft reset worked a treat - no idea why I didn't do that first! thanks 🙂
