I have been using Zoom successfully for over a month. From Wednesday 13th May I started to experience timeout problems. These have become successively worst and now I often simply cannot connect and am sent a 5003 error suggesting blocking by a firewall or bad proxy. All of this applies only when I am connected through my own BT broadband. If I connect via BT Fon everything still works fine. I realise this is rather a technical question but hope someone may be albe to help me to understand what I need to do to correct it please. Many thanks.
Check that BT Protect is not activated on your BT Account, as that can give connection issues.
Try turning Smart Setup off if you have not already done it.
Many thanks both ideas sounded promising but have sadly not helped.
