sherlock30
Message 1 of 1
a fix for nexus and Chromecast on bt
Been struggling for a few weeks now casting from my nexus to Chromecast via BT but have finally found a solution.
First of all make sure your google play services is the latest addition you can find the latest version here http://www.apk4fun.com/apps/com.google.android.gms/ after installation turn your device off and back on and try to cast if it does not work do the following which worked for me.
First of all install a older version of play services once installed go into your app manager and force stop google play services
Turn of your device and then back on.
Go back to your google play services and restart the play services.
Then go to your Chromecast and start it up, it will tell you that it needs the latest version of play services to work, follow the on screen instructions and let it update.
Once done exit everything and turn the device on and off then reconnect to your Chromecast and you should be good to go.
If not pester google like I did, it has nothing at all to do with the BT home hub all issues are Google's latest updates.
