Kerridge
Message 1 of 12
adsl max or adsl2+
hi should i be on adsl or adsl2+ what speed should i be getting. i am on a very line
tom kerridge
1. Product Name: HomeHub4
2. Serial number: +076281+1706004804
3. Firmware version: v0.07.0
4.01235-BT (Type B) Last updated 27/12/20174. Board version: 01B
5. DSL uptime: 0 days, 09:24:12
6. Data Rate: 448 / 3328
7. Maximum Data Rate: 1080 / 3572
8. Noise Margin: 20.0 / 9.2
9. Line Attenuation: 31.5 / 47.0
10. Signal Attenuation: 0.0 / 47.0
11. Data sent/received: 98.0 MB / 2.6 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4GHz wireless network/SSID: BTHub4-767G
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA & WPA2 (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub4-767G
19. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))
20. 5GHz wireless security: WPA2 Only
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: e0:51:63:4a:29:54
24. VPI/VCI: 0/38
25. Modulation: G.992.1(DMT)
26. Latency type: Interleaved
27. Software variant: -
28. Boot loader: 0.5.0-BT (Wed Nov 12 11:47:59 2014)
11 REPLIES 11
imjolly
Message 2 of 12
Re: adsl max or adsl2+
You are on adslmax
enter your phone number and post results. Remember delete number https://www.dslchecker.bt.com/
Kerridge
Message 3 of 12
imjolly
Message 4 of 12
Your exchange has adsl2 valuable and as you can see the estimated down speed is similar on adslmax to adsl2 but the up speed would be about 100% better. The mods may be able to help with adsl2 but sometimes it can make your line less stable
Kerridge
Message 5 of 12
i know it would only be a small increase but when you don't have a fast download rate every little helps
thanks tom
imjolly
Message 6 of 12
Mods will try and help get you upgraded to adsl 2. They will post here tomorrow
DanielS
Moderator
Moderator
Message 7 of 12
Good morning @Kerridge,
We'll look into it for you. There isn't always an increase when you switch from ADSL1 to ADSL2 but it's worth trying going by the BT Wholesale checker. To get in touch with us, click on my user name and then on contact the mods. Complete that form and it'll be sent to one of us to complete.
DanielS
StuartH
Moderator
Moderator
Message 8 of 12
Hi @Kerridge
I've picked up your email and I've requested the change for you.
I'll call you tomorrow to see if the connection, at least the upload part has improved.
Stuart
Kerridge
Message 9 of 12
hi thanks Stuart thanks for your help, will be out till 4pm tomorrow 23.01.18
thanks tom
StuartH
Moderator
Moderator
Message 10 of 12
Hi @Kerridge
Thanks for taking my call today glad to hear the speeds have improved on the upload.
Should you need help again in future please post back.
Stuart
