GIBB1978
Message 1 of 6
adsl to adsl2
Hi BT
Hope you can help please ?
i was told that the work would be done on the 12th Dec !!!
but am trying to check if this has happened and all was okay ?
Regards Roger
5 REPLIES 5
Webby
Message 2 of 6
Re: adsl to adsl2
What hub are you using?
The connection stats within the router will tell you the modulation type. If you can post that we'll be able to tell you.
GIBB1978
Message 3 of 6
Re: adsl to adsl2
Thanks for your reply,
i will have a look at the router ?
can you tell we where i will find the modulation type ?
Regards Roger
Webby
Message 4 of 6
Re: adsl to adsl2
That depends on the router you're using, which is why I asked that first 😉
For the hub 4 it's under the troubleshooting section, then Helpdesk. Down near the bottom of that page it shows the modulation.
GIBB1978
Message 5 of 6
Re: adsl to adsl2
Sorry,
yes its a Hub 4
I will go and have a look !!!!!!!!!!
what should it read if the update happened ?
Regards Roger
john46
Message 6 of 6
Re: adsl to adsl2
If you post the information asked for we will be able to tell you if you are on adsl 2+
