neale
Message 1 of 3
advice please
Hi, noticed on my hub stats that I have gone from interleaved to fast. Is this good or bad. Have already e mailed mods about my speed. On option 3.
Line state:Connected
Connection time:3 days, 17:32:56
Downstream:1.523 Mbps
Upstream:944 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):9.3 dB / 6.4 dB
Line attenuation (Down/Up):61.5 dB / 34.9 dB
Output power (Down/Up):17.0 dBm / 12.8 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):11540 / 1010
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):7722 / 1137
Error Seconds (Local/Remote):10979 / 4765
2 REPLIES 2
Message 2 of 3
Re: advice please
Hi do not worry about being on fast if the exchange equipment sees your line as unstable it will switch it back to interleave as to your speed when your noise margin reduces to the default 6db you should with your line attenuation get a maximum 2.3mb download Unfortunately your line length 4.4 km you are going to see very little improvement on your previous connection
neale
Message 3 of 3
Re: advice please
Thanks for the advice.
