wysesr2
Message 1 of 4
also unable to activate bt sport online
I have the BT Sport app loaded on my IPad, have used it in the past but not for a while.
I went to use it yesterday and cannot login as I need to activate the app however when I follow the link to do this and login on BT.com I get a blank page, can you help?
User ID is **Edited**
3 REPLIES 3
DavidM
Moderator
Moderator
Message 2 of 4
Re: also unable to activate bt sport online
Hi wysesr2,
Welcome and thanks for posting. Sorry you're having problems with the App. Take a look at The BT Sport App won't open on my device and let us know if that helps.
Cheers
David
wysesr2
Message 3 of 4
No use, I have already un-installed and re-installed.
I can access the App just cant login to it!
DavidM
Moderator
Moderator
Message 4 of 4
Hi wysesr2.
Sorry it's taken a while to get this sorted for you. It took a bit of digging around in the background but I'm glad it's all sorted now.
Cheers
David
