staking
Message 1 of 7
anyone in N.Ireland having problems connecting or connections dropping ?
Started around 5.20pm
orange light then blue light etc on the hub, i phoned bt tech, they said there was a fault on the line, but just wondering if its just me or through out ni.  county down area.
6 REPLIES 6
staking
Message 2 of 7
Re: anyone in N.Ireland having problems connecting or connections dropping ?
connection cutting out more often now
events log from hub
Recorded events
Time and dateMessage
May 21 18:35:53
2011
( 2006.770000) RTNL:
Received ERROR reply 'No such process' for message type 0x19
May 21 18:35:22
2011
ERR
2011-05-21T17:35:22Z cwmp: mt_cwmp: session error: Could not resolve
host
May 21 18:32:42
2011
( 1816.140000) RTNL:
May 21 18:31:51
2011
( 1765.480000) Admin
login successful by 192.168.1.64 on HTTP
May 21 18:30:01
2011
ERR
2011-05-21T17:30:01Z cwmp: mt_cwmp: session error: Could not resolve
host
May 21 18:27:11
2011
( 1485.480000) RTNL:
May 21 18:26:43
2011
ERR
2011-05-21T17:26:43Z cwmp: mt_cwmp: session error: Could not resolve
host
May 21 18:24:33
2011
( 1327.440000) RTNL:
May 21 18:24:03
2011
ERR
2011-05-21T17:24:03Z cwmp: mt_cwmp: session error: Could not resolve
host
May 21 18:17:36
2011
( 910.300000) RTNL:
May 21 18:16:19
2011
ERR
2011-05-21T17:16:19Z cwmp: mt_cwmp: session error: Could not resolve
host
May 21 18:04:02
2011
( 96.060000) WGET:
Error connecting to host https://pbthdm.bt.motive.com/cwmpWeb/CPEMgt
(66.193.112.93:443)
May 21 18:03:29
2011
( 82.140000) RTNL:
May 21 18:03:05
2011
( 58.900000) RTNL:
May 21 18:03:02
2011
( 55.890000) HTTP
server returned error 404
May 21 18:02:57
2011
ERR
2003-01-01T00:00:32Z cwmp: mt_cwmp: session error: Could not resolve
host
May 21 18:02:33
2011
( 26.450000) DVA
started
May 21 18:02:32
2011
( 25.450000) Device
with no MAC wasn't assigned a MAC
May 21 18:02:32
2011
( 25.120000)
sys_if_stats_reset failed for atm0
May 21 18:02:30
2011
( 23.050000) No primary
and rollover device found
dweller770
Message 3 of 7
I'm from Co. Down and haven't been disconnected all day.
Is your landline working ok?
Pilot25dmc
Message 4 of 7
Co Armagh here, nothing to report.
staking
Message 5 of 7
landland is fine.
staking
Message 6 of 7
fixed but now slow speeds
update
bt seem to have sorted the problem, connection is steady now
but now another problem, speed has been reduced !
when i first got it infinity installed i was on 18mb then few months back 15mb  now im on 13mb !
isnt really what im paying for !
dweller770
Message 7 of 7
Re: fixed but now slow speeds
What option are you on? Are you testing via a wired connection?
Try a wired connection at BT Speed Tester then come back and post your results.
