dodger1
Message 1 of 2
app blocking
when trying to download apps onto a fire tv stick,the message - your phone is blocking installation of apps from unknown sources.I am guessing it's something to do with my smart hub. HELP! i'm not realy tech savvy
1 REPLY 1
gg30340
Message 2 of 2
Re: app blocking
It is a warning from the Fire Stick not your hub. If you don't download apps from the Playstore or the recognised store on the Fire TV Stick you will get that message. It is to stop you downloading potentially malicious apps. There will be a setting that you can change to allow you to download if you want to take the risk.
