jamjar62
Expert
Message 1 of 11
asus dsl-ac68u ping help
Hi All  I have set up the Asus DSL -AC68U  and everything seemed great , but now my ping has gone from 9 to 22   but the upload and download speeds are still the same , what could be doing this ?
JamJar62
10 REPLIES 10
brookheather
Expert
Message 2 of 11
Re: asus dsl-ac68u ping help
Are you on FastPath or Interleaved - make sure G.INP is enabled otherwise you may be on Interleaved which will increase your ping - I had the same problem.
jamjar62
Expert
Message 3 of 11
i,m not sure what i,m on but i have G.INP enabled and it was on 9 ping  , just wondered if i should update the firmware ,but always scared to do this as they always seem to go crazy !   😞
JamJar62
TimCurtis
Guru
Message 4 of 11
Lookng at the DSL Log page in the router what does it say for Path Mode , Interleave Depth & DSL Modulation?
jamjar62
Expert
Message 5 of 11
in the path mode is says interleaved  ....
JamJar62
TimCurtis
Guru
Message 6 of 11
That'll explain the ping problem then. Hopefully over the next few weeks of a stable connection the DLM willl get you on to Fastpath.
An answer to the other items I requested might also help.
jamjar62
Expert
Message 7 of 11
Thanks so I don't have to contact BT to ask them to change it onto fastpath ? Is it monitored and done automatically in the exchange ?
JamJar62
licquorice
Message 8 of 11
Yes.
brookheather
Expert
Message 9 of 11
Also make sure vectoring is enabled.
licquorice
Message 10 of 11
Vectoring is only deployed on a very few trial cabinets.
