imjolly
Message 11 of 19
Re: bRAS profile stuck - Possible to get a reset?
Yes just maintain the stable connection and DLM will drop noise margin automatically
john46
Message 12 of 19
as I posted it can take up to 10 days to start and drop to the default level
fornowagain
Message 13 of 19
Yes sorry I saw that, I mistakenly thought it was three days.
One question, how much tolerance does the DLM have? If the line drops within those 10 days, does the day count start all over again?
Just some advice. In the future if I wanted to change the modem or adjust the db. Is it best to leave a delay, an hour for example before re-synch attempts? Really want to avoid this again.
imjolly
Message 14 of 19
the noise margin could reduce in 3 days but it is normally longer.  if conenction resets then your timescale starts again
I found that using the router interface to disconenct gave a 'soft' reset as against just switching off or pulling out rj11 cable.  there is no need to leave an hour delay but any manual resets I used to do about midday when noise margin normally at highest giving bit more scope for better conenction speed
PaddyB
Moderator
Moderator
Message 15 of 19
Hi @fornowagain,
I gave you a quick call, I'm sorry I didn't get speaking to you.
I've carried out a profile reset and this should see your speeds return to normal. I'll check back with you on Thursday to see how you connection is preforming.
PaddyB
fornowagain
Message 16 of 19
Thank you, sorry I missed your call.
Looking good Smiley Very Happy
Download speedachieved during the test was - 11.44 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 16 Mbps
Connection Speed 18139 kbps 1187 kbps
Line Attenuation 20.0 db 9.7 db
Noise Margin 4.8 db 6.2 db
imjolly
Message 17 of 19
looking good now
PaddyB
Moderator
Moderator
Message 18 of 19
Hi @fornowagain,
I retested your connection again today and its looking pretty good. Your sync speed is still sitting at just over 18 Mbps.
I sent you an email. If you notice and issue with your connection, drop me a reply.
PaddyB
fornowagain
Message 19 of 19
Hi, thank appreciate the email. Swapped out the ancient DG834GT modem for a Billion 8800NL, set line to 4db as before. 3hrs up and counting. Monitoring with Routerstats.
Download speedachieved during the test was - 15.28 Mbps
IP Profile for your line is - 17.08 Mbps
Upload speed achieved during the test was - 1Mbps
Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps
Connection Speed 19355 kbps 1231 kbps
Line Attenuation 19.5 db 8.9 db
Noise Margin 4.0 db 6.2 db
