Message 1 of 4
bad upload speed
Hi there,
I am extremely fed up with BTs offer of broadband internet in my flat.
There is a Fibre line near my building even and only 1 MBps upload can be offered.
I use this bad broadband internet since April 2021 and need better upload speed. It never reaches higher than 0.6 Mbps.
Any help suggested apart from changer my broadband provider?
Thanks.
KR
Kim
3 REPLIES 3
Message 2 of 4
Re: bad upload speed
Changing provider probably won't help as your speed will be dependent on your line capability.
Enter your phone number in the checker and post a screenshot of the result, edit out your number from the screenshot before posting. https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 3 of 4
Message 4 of 4
as you can see there is no fibre connections available to you yet regardless of ISP using openreach network - unless you can get virgin
your connection speed is above expected and your up speed is about best you can get on adsl2+
