bazal
Message 1 of 14
bb keeps losing ip address
hi
     when I switch on my computer the network symbol has a yellow triangle over it ?. when I put the cursor over it, I get the following........UNKNOWN IP ADDRESS ......and I am unable to access the internet
when I try to repair the problem I get ......LOCAL AREA CONNECTION DOESNT HAVE A VALID IP CONFIGURATION....Then resets the problem. This has happened on a regular basis , is this normal
13 REPLIES 13
Message 2 of 14
Re: bb keeps losing ip address
are you connecting wireless?
bazal
Message 3 of 14
hi
no i am connected by cable and i am next to the main socket
Message 4 of 14
so your router is connected to the internet but your pc is having problems connecting to router.  as you are using ethernet is the driver for your network card up to date?
bazal
Message 5 of 14
hi
will check
bazal
Message 6 of 14
hi
  have checked the driver and its up to date ?
Message 7 of 14
hi try changing the ethernet port in case it has a fault
bazal
Message 8 of 14
hi
have changed port will see if it cures the prob will get back in a couple of days
bazal
Message 9 of 14
bazal
Message 10 of 14
Hi have tried a different port but still have the problem. Have looked at my adsl settings which has dropped from fast to interleaved, has any one got any ideas
