Message 1 of 2
best wifi 6 router
Hi I currently get the 150 speed with fibre 100.  I receive 150mb on wifi even in the furthest away room of my house so all good.
I have connected loads of gadgets, security system , xbox, the usual streaming and now a new oculus quest 2 VR headset (which is awesome).
It can, along with my phone, handle wifi 6.
I was thinking of taking on a new router that has 1- dual band (v smart hub2) , wifi 6 and good wifi range that I can plug  in and easy to set up so I can change SSID to I keep the same SSID currently have and use this for 2.4 and set up new one for 5.
Does the wifi 6 use 5 or 2.4 or both - sorry for being thick!
I was also thinking of paying the £12pm more to get the 300 speed v 150.    The 900 sounded ideal - until I seen the cost went from £39.99 to £68.99 !!!!!
1 REPLY 1
Message 2 of 2
Re: best wifi 6 router
https://www.techspot.com/article/1769-wi-fi-6-explained/ scroll down to the comparison table
