Message 1 of 11
bouts of very variable broadband speed from usual 16/4 down to 5.9/0.4 Mbps
I live in the East Riding of Yorkshire just on the edge of a market town and my bb comes over several (about 5) Kms of copper. (The route is extremely non-optimal as the copper runs along 2.5 sides of a triangle, with the nearest fibre cabinet only about 1 Km away).  My bb speed has been suffering bouts of serious (i.e. vey noticeable) degradation from about 16up/4 down to 5.9/0.4 as measured by the Google spped test as well as others.  I have several screen snips showing test results.  I have been told there is no chance I can upgrade to fibre due to the amoint of digging that would be ivolved.
Can someone tell me what the most likely causes are and how the problem should best be investigated?  Thanks.
10 REPLIES 10
Message 2 of 11
Re: bouts of very variable broadband speed from usual 16/4 down to 5.9/0.4 Mbps
@ajd111
With the upload speed of 16Mb, you must be on a FTTC connection not ADSL, which is why I have moved this to the "fibre" broadband board.
Please provide the connection information from your BT Home Hub, and the expected speed range from the BT broadband availability website. Please do not post any personal information.
Message 3 of 11
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 11
Thanks for your helpful reply imjolly.  I'm afraid I don't use the BT router, I use a Draytek 2860.
The broadband checker says
Telephone Number 01759xxxxxx on Exchange POCKLINGTON is served by Cabinet 2
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate (Mbps)
Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
28.5
18
5.3
3.4
16.5
Available
Available
VDSL Range B (Impacte
27.9
16.5
5.2
3.1
12.5
Available
Available
Featured Products
Downstream Range (Mbps)
Availability Date
FTTP Install Process
FTTP on Demand
330
50
Available
ADSL Products
Downstream Line Rate (Mbps)
Downstream Range(Mbps)
ADSL Availability Date
WBC SOADSL Availability Date
Left in Jumper
WBC ADSL 2+
Up to 4
2.5 to 6.5
Available
WBC ADSL2+ Annex M
Up to 4
Up to 0.5
2.5 to 6.5
Available
ADSL Max
Up to 3
2 to 6
Available
WBC Fixed Rate
1
Available
Fixed Rate
1
Available
Observed Speeds
VDSL
Max Observed Downstream Speed
19.99
Max Observed Upstream Speed
4.91
Observed Date
2021-07-24
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise Environment
Status
Bridge Tap
N
VRI
N
NTE FacePlate
N
Last Test Date
14-07-2021
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
N
SOADSL Restriction
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Oct 2013. The Formal Retirement date for IPstream is from 30 Jun 2014.
The web interface to my router says
adsl statusadsl status more
Type ? for command help
> adsl status
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 19998000 bps US Actual Rate : 4914000 bps
DS Attainable Rate : 23258532 bps US Attainable Rate : 4914000 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 28 dB Cur SNR Margin : 8 dB
DS actual PSD : 7. 2 dB US actual PSD : 11. 2 dB
NE CRC Count : 135 FE CRC Count : 28344
NE ES Count : 40 FE ES Count : 27323
Xdsl Reset Times : 0 Xdsl Link Times : 3
ITU Version[0] : 00000000 ITU Version[1] : 00000000
VDSL Firmware Version : 05-07-06-0D-01-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 32 dB Far SNR Margin : 5 dB
CO ITU Version[0] : b5004244 CO ITU Version[1] : 434da48c
DSLAM CHIPSET VENDOR : < BDCM >
> adsl status more
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 1
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 0 206931 (seconds)
ES : 40 27323 (seconds)
SES : 4 47 (seconds)
LOSS : 0 3 (seconds)
UAS : 27 54553 (seconds)
HECError : 0 0
CRC : 135 28344
INP : 0 220 (symbols)
INTLVDelay : 0 13 (1/100 ms)
NFEC : 156 32
RFEC : 12 16
LSYMB : 1344 16
INTLVBLOCK : 78 32
AELEM : 0 ----
The Draytek page describing this is at
https://www.draytek.co.uk/support/guides/kb-dsl-status-more
I ran the quiet line test and the line was very quiet, no detectable background or spikes.
I hope this helps. Kind regards,
Jon
Message 5 of 11
Hello, is anyone there? I'm still getting bouts of degraded service. All suggestion appreciated,#Jon
Message 6 of 11
from dslchecker your expected down connection speed range is 28/18 with handback at 16.5mb and you currently have 20mb .  your up speed is 5mb and that is top of expected range
I cannot see internet connection time in your stats but speed has been same since 24/7.  Have you been having connection problems with router dropping connection or maybe manual resets trying to improve speed or maybe both?
have you tried using the test socket with a filter to see if that helps?
Message 7 of 11
Here is well fastest then don't put Hi imjolly, thanks for your reply.  On my desktop which is connected to the router by copper, I normally see over 20Mbps download and 4 to 5Mbps upload.  I haven't reset the router recently.
I enclose a traffic flow graph from the router though as this is the first graph of this type that I have seen I'm reluctant to try and interpret it.  I realise that it indicates flow rather than the potential for flow.210727 11.57 traffic graph from router.PNG
I also enclose the DSL status from the router in case that can be of help.
Diagnostics >> DSL Status
GeneralTone Information|  Refresh |
ATU-R Information
        Type:VDSL2
        Hardware:Annex A
        Firmware:05-07-06-0D-01-07
        Power Mngt Mode:DSL_G997_PMS_L0
        Line State:SHOWTIME
        Running Mode:17A
        Vendor ID:00000000 00000000
ATU-C Information
       Vendor ID:b5004244 434da48c [BDCM]
Line Statistics
 Downstream            Upstream
Actual Rate19998Kbps4914Kbps
Attainable Rate25493Kbps4914Kbps
Path ModeFastFast
Interleave Depth11
Actual PSD7. 2dB11. 2dB
 Near End                 Far End
TrellisONON
BitswapONON
ReTx0 1
SNR Margin11dB5dB
Attenuation28dB32dB
CRC18328370
FECS0s207033s
ES52s27349s
SES7s47s
LOSS0s3s
UAS27s54553s
HEC Errors00
RS Corrections00
LOS Failure00
LOF Failure00
LPR Failure00
NCD Failure00
LCD Failure00
NFEC15632
RFEC1216
LYSMB134416
Regarding filters, I suspect that the wall plate has a filter inside it.  The back part of the wall plate has the BT logo on it in the front part has two sockets one with the router logo and the other with the telephone logo.  The wall plate is marked ADSL vV 1.0.
I hope that helps.  All suggestions appreciated,
Jon
Message 8 of 11
A couple of additions to the previous posting. Please excuse the garbage on the first line (poor use of dictation software). Regarding filters and the wall plate: I think it was installed about five or six years ago.
Message 9 of 11
which master do you have
still can't see anything showing internet connection time (not system time)
It looks like you are in a banded profile hence stuck at 20mb and why I keep asking about length of connection time.
if you line is now stable then banding should release automatically but that can take a few weeks to happen
Message 10 of 11
Hi imjolly, thanks for your reply.  I think I have box number five.  Just to be sure I enclose a photograph.
I've looked up banded profiles on the Internet and understand what's going on now.  I think I need to contact Draytek to see if the router can tell me more about my Internet connection time.  Right now I'm obtaining 17 Mbps download speed using the Google checker (and only 11.7 using the Which checker) so presumably if limiting due to banding has been going on then it has been being relaxed in my favour.  So if I observe new periods of slow download speed then it presumably wouldn't be due to banding (unless banding is chipping in all the time).  I do wonder whether contention on the other side of the FTTC Cabinet might be a factor.  Can that be ruled out?
Kind regards, Jon
