ani
Newbie
Message 1 of 5
broadband abroad
i want to use broadband in spain how do i do this just connect to fon then put my email addi in...please help also if i have total broadband do i pay for the munutes thanks
4 REPLIES 4
Community Manager
Community Manager
Message 2 of 5
Re: broadband abroad
Hi Ani,
Thanks for the post and welcome to the forum.
You will be able to use BT Fon abroad.  Please take a look at this link for more information BT Fon FAQ's
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Distinguished Guru
Message 3 of 5
Hi Ani.
You should be able to use Fon abroad, it does depend where you are going in a specific Country.
See here :-
http://bt.custhelp.com/app/answers/detail/a_id/10899/c/346,502
and
http://www.bt.com/static/wa/wifi/pages/findhotspots.html
and
http://www.btfon.com/support/faqs
homeinmk
Message 4 of 5
Dont forget to turn off the 3G or if you are on the old s620 turn of the phone in Comms Manager before activating your wi-fi to log into Fon or any other "free wi-fi" access point. This will make sure that you are using the free access and not accidentally using call data.
Incidentally I have used this to get VOIP on several "free Wifi" abroad.
grandadbaza
Message 5 of 5
Does my  option 1 package allow me to connect to fon in  france or do I need to upgrade to a higher package
Baza
