my broadband and landline is due to be activated on the 24/06/19 my landline is now working as I didnt have a working line before will there be a chance that my broadband will active before Monday as I assume it works through the same line
Possibly, possibly not. Although they use the same physical line, the 2 services are totally independent of each other and will be activated separately.
thanks I just assumed they were both activated at the same time by the openreach engineer
The only way you'll find out if its been activated is to connect your hub and give it a try.
