peoline
Message 1 of 4
broadband connection dramaticly slow
In the last few days my broadband connection has dropped to about 60kb.  The BT speed tester says i connect at 8.1mb, but i can't download over 60kb.
The homehub settings are:
ADSL line status
Line stateConnected
Connection time0 days, 1:42:12
Downstream8,128 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)10.3 dB / 30.0 dB
Line attenuation (Down/Up)3.0 dB / 4.0 dB
Output power (Down/Up)
I've tried changeing all the hubs cables and the filter, i've also changed the hub but to no avail, it mistifies me as up until monday i was downloading at about 6mb.
7.8 dBm / 11.5 dBm
<script type="text/javascript">// var showButton = new Button("show","","More Details", function(){GoAndRemember('bb_dsl.lp','dt=1');}); // // ]]></script>
3 REPLIES 3
Message 2 of 4
Re: broadband connection dramaticly slow
you are connecting at 8.1 mb you need to run the bt speed tester post the full results from http://speedtester.bt.com/ and post the details back here the most important thing at the moment is not to restart the hub for the next 3/5 days while your line stabilises if after 5 days your speedtest results have not improved you will need to contact the forum mods which we can put you in touch with
NilSatisOptimum
Recognised Expert
Message 3 of 4
Blimey do you live in the exchangeSmiley Wink
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
Message 4 of 4
The best attenuation figure I think I gave ever seen NSO
