rustygoat
Message 1 of 4
broadband crashing again after months of being ok
hi all
its started crashing again and i've forgotten the drill
its been lovely for months since the cables from the outside juction box to inside was replaced and the junction box moved to cover it from the bad weather, but yesterday it started crashing again and its been at it lots of times today
is there away to check if BT have updated the software in the router ? or if there is a fault at the exchange ?
reason i think its out side of the house is it crashed this morning at 6.30 when i was the only one up and nothing was on the internet
over the past year the overhead cable from the first connection pole to home has been changed and the cable from the outside connection box to inside socket has been changed
any suggestions please
3 REPLIES 3
rustygoat
Message 2 of 4
Re: broadband crashing again after months of being ok
just looking at the router logs (BT hub 4)  since these crashes started on saturday afternoon there is a lot more log information recorded
also now showing
825793.500000) PPP LCP Send Termination Request [User request]
and then internet crashes
john46
Message 3 of 4
your hub firmware and its last update are shown on the hub help desk page
you can check your exchange for problems here https://www.bt.com/consumerFaultTracking/public/faults/tracking.do;jsessionid=0X7GVLnXC3zNTnPxDfpnMh...
rustygoat
Message 4 of 4
thanks
the firmware is 31/10.15 so its not caused by an update
it failed twice in thenight 2210 and about 0102
the event log is below, anyone see anything amiss
01:01:39, 12 Sep.(854209.300000) DSL is down after 155 minutes uptime
01:01:39, 12 Sep.(854209.300000) ETHoA is down after 155 minutes uptime
01:01:38, 12 Sep.(854208.890000) PPPoA is down after 155 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
01:01:34, 12 Sep.(854204.470000) PPP LCP Send Termination Request [User request]
00:57:28, 12 Sep.OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [86.146.183.220]:35624-​>[64.186.176.170]:443 on ppp0)
00:55:05, 12 Sep.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 185.94.111.1-​>86.146.183.220 on ppp0)
00:35:51, 12 Sep.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19-​>86.146.183.220 on ppp0)
00:29:53, 12 Sep.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 206.117.25.90-​>86.146.183.220 on ppp0)
00:23:53, 12 Sep.IN: BLOCK [16] Remote administration (TCP [37.48.77.131]:36866-​>[86.146.183.220]:22 on ppp0)
00:15:20, 12 Sep.IN: BLOCK [16] Remote administration (TCP [118.102.177.164]:47213-​>[86.146.183.220]:22 on ppp0)
00:06:43, 12 Sep.IN: BLOCK [16] Remote administration (TCP [124.205.66.66]:21824-​>[86.146.183.220]:22 on ppp0)
23:57:41, 11 Sep.IN: BLOCK [16] Remote administration (TCP [46.165.105.166]:55360-​>[86.146.183.220]:80 on ppp0)
23:57:41, 11 Sep.IN: BLOCK [16] Remote administration (TCP [46.165.105.166]:55359-​>[86.146.183.220]:80 on ppp0)
