stewied88
Message 1 of 4
broadband download speed suddenly dropped
hi there, i've noticed that in the last week my download speed has reduced from around 3mbs to below 1.5mbs in the last week.
reading through other posts ive ran a few tests on the router and on btspeedtest and the result are below.
how do i go about getting my ip profile reset?
thanks
btspeedtest
 Download speedachieved during the test was - 1372 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :3360 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 1500 Kbps
router resuts
ADSL line status
Connection information
Line state    Connected
Connection time    0 days, 0:21:06
Downstream    3,360 Kbps
Upstream    448 Kbps
ADSL settings
VPI/VCI    0/38
Type    PPPoA
Modulation    ITU-T G.992.1
Latency type    Interleaved
Noise margin (Down/Up)    12.4 dB / 21.0 dB
Line attenuation (Down/Up)    55.0 dB / 31.5 dB
Output power (Down/Up)    18.5 dBm / 11.9 dBm
3 REPLIES 3
Message 2 of 4
Re: broadband download speed suddenly dropped
Hi your ip profile has dropped because of hub disconnetions/restarts if left powered up 24/7with no restarts your profile will rise automatically after 3/5days of stable connection
stewied88
Message 3 of 4
thanks, i'll wait and see if things improve and report back
stewied88
Message 4 of 4
Everything appears to be back to normal now after leaving the hub undisturbed for a few days. 🙂
