Message 1 of 7
broadband drops out continuously
switched from Sky on tuesday this week (Sky wasn't very fast - but it worked) - upon first connection, the BT service started dropping out and back on, probably every minute -- settled down to being random. now, 3 days later it is still cycling of / on pretty much continuously.
i have tried two sockets - no difference.  reset router - no difference.
BT diagnostic tool fault tracker says the issue is outside my home - and will be resolved in a week.
was on hold to help number for 1 hour 15 mins, then cut off 5 seconds after it was answered ! now been on hold for  a second time for around an hour and counting.
absolutely terrible experience as a new customer.
6 REPLIES 6
Message 2 of 7
Re: broadband drops out continuously
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
are you using the test socket with a filter to see if that stabilises your connection
make sure you turn off smart setup   https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 7
any clues ?
I have reported a fault. the system then said it was being worked on. then I got a text to say that I need to book an engineer --- but there is no way to book an engineer. this is some kind of technical hell. I will be swapping back to SKY in the next few days.
Message 4 of 7
Need the other information I requested but as you are going back to SKY in next few days there is no point in making any changes
Message 5 of 7
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information . see below.
6:21:54, 26 Jun.
Receive a DHCP request
16:21:19, 26 Jun.
16:20:14, 26 Jun.
16:20:12, 26 Jun.
16:19:46, 26 Jun.
Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
16:19:45, 26 Jun.
16:19:43, 26 Jun.
DHCP device Connected: 192.168.1.235, 90:2e:1c:e4:1c:13, unknown
16:19:43, 26 Jun.
5G Client associate from 90:2e:1c:e4:1c:13 (IP=192.168.1.235) RSSI=-61, Rate=585Mbps, host
16:19:43, 26 Jun.
LAN [ADD] ARP 192.168.1.235 with 90:2e:1c:e4:1c:13 from br0(wl0)
16:19:43, 26 Jun.
ARP [add] br0(wl0) 192.168.1.235 90:2e:1c:e4:1c:13
16:19:43, 26 Jun.
16:19:42, 26 Jun.
16:19:42, 26 Jun.
WHW INFO A station (SmartHub2)IF[5G](0C:8E:29:BB:56:97):STA(90:2E:1C:E4:1C:13)(Legacy Device) join WHW infrastructure
16:19:05, 26 Jun.
16:18:35, 26 Jun.
16:18:34, 26 Jun.
ARP [add] br0(wl1) 192.168.1.72 4c:57:ca:0d:2f:45
16:18:34, 26 Jun.
ARP [del] br0 192.168.1.72 4c:57:ca:0d:2f:45
16:18:02, 26 Jun.
CWMP: HDM socket closed successfully.
16:18:02, 26 Jun.
CWMP: HTTP authentication success from pbthdm.x.x.x
16:18:02, 26 Jun.
CWMP: HDM socket opened successfully.
16:18:02, 26 Jun.
CWMP: session completed successfully
16:18:02, 26 Jun.
16:18:01, 26 Jun.
16:18:01, 26 Jun.
16:18:00, 26 Jun.
CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
16:18:00, 26 Jun.
CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
16:18:00, 26 Jun.
CWMP: Initializing transaction for event code 4 VALUE CHANGE
16:17:58, 26 Jun.
16:16:57, 26 Jun.
SIP WAN UP
16:16:56, 26 Jun.
16:16:51, 26 Jun.
NTP synchronization success
16:16:51, 26 Jun.
DHCP device Connected: 192.168.1.107, 44:e4:ee:9b:19:b9, unknown
16:16:51, 26 Jun.
16:16:50, 26 Jun.
LAN [ADD] ARP 192.168.1.107 with 44:e4:ee:9b:19:b9 from br0(wl1)
16:16:50, 26 Jun.
ARP [add] br0(wl1) 192.168.1.107 44:e4:ee:9b:19:b9
16:16:45, 26 Jun.
16:16:45, 26 Jun.
16:16:43, 26 Jun.
16:16:43, 26 Jun.
DHCP device Connected: 192.168.1.169, c8:69:cd:d1:8f:f5, Apple-TV-2
16:16:43, 26 Jun.
LAN [ADD] ARP 192.168.1.169 with c8:69:cd:d1:8f:f5 from br0(eth0)
16:16:43, 26 Jun.
ARP [add] br0(eth0) 192.168.1.169 c8:69:cd:d1:8f:f5
16:16:43, 26 Jun.
16:16:40, 26 Jun.
WAN Sensing Auto sensing Complete, interface selected
16:16:40, 26 Jun.
WAN Sensing Auto sensing Running
16:16:39, 26 Jun.
WAN IPv6 Global unicast prefix / length: 2a00:23c2:ac80:2b00::/56
16:16:39, 26 Jun.
WAN IPv6 Global unicast address allocated: 2a00:23c2:ac80:2b00::1/64
16:16:39, 26 Jun.
WAN DHCPv6 events: BOUND
16:16:38, 26 Jun.
DSL Link Up: Down Rate=45393kbps, Up Rate=1451
16:16:38, 26 Jun.
16:16:38, 26 Jun.
Success - secondary DNS servers
16:16:38, 26 Jun.
16:16:38, 26 Jun.
Success - primary DNS servers
16:16:38, 26 Jun.
WAN connection WAN2_INTERNET_PTM connected
16:16:37, 26 Jun.
WAN DHCPv6 events: INIT
16:16:37, 26 Jun.
PPP: IPCP up
16:16:37, 26 Jun.
PPP IPCP Receive Configuration ACK
16:16:37, 26 Jun.
PPP IPV6CP Receive Configuration ACK
16:16:37, 26 Jun.
PPP IPCP Send Configuration Request
16:16:37, 26 Jun.
PPP IPCP Receive Configuration NAK
16:16:37, 26 Jun.
PPP IPCP Send Configuration ACK
16:16:37, 26 Jun.
PPP IPCP Receive Configuration Request
16:16:37, 26 Jun.
PPP IPV6CP Send Configuration ACK
16:16:37, 26 Jun.
PPP IPV6CP Receive Configuration Request
16:16:37, 26 Jun.
PPP IPV6CP Send Configuration Request
16:16:37, 26 Jun.
16:16:37, 26 Jun.
PPP: CHAP authentication succeeded
16:16:37, 26 Jun.
PPP CHAP Receive success : authentication successful
16:16:36, 26 Jun.
PPP CHAP Receive Challenge
16:16:36, 26 Jun.
PPP: LCP up
16:16:36, 26 Jun.
PPP LCP Receive Configuration ACK
16:16:36, 26 Jun.
PPP LCP Send Configuration ACK
16:16:36, 26 Jun.
PPP LCP Receive Configuration Request
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal. Yes I have done this - it sounds a bit **bleep** but it always has.
are you using the test socket with a filter to see if that stabilises your connection. Nope, it's still doesn't work - bear in mind I've had broadband for 8 years through the same socket, and this only went wrong wit the new BT account this week.
Yes done that.
Message 6 of 7
I had to wait a long time to get through to BT today also for similar reasons, but once through to them the lady suggested to send out an engineer... That's pretty much your best bet if you did want to stay with BT. The line fault is likely not your responsibility if the test socket is also noisy.
It'd be helpful to see the technical log (information tab not event log if possible) as that can help rule out other issues.
Without resolving the line fault/high noise you'll have the same story with every provider that falls under Openreach, at-least until your speeds drop to unreasonable levels whilst DLM stabilises your line.
But yeah, information tab under technical log will give people more information and hopefully help you!
Message 7 of 7
As already posted it is the technical log information not the actual logs
have you tried connecting to test socket? Is the line noise you hear when connected to test socket otherwise it could be your own wiring causing the problem
