Message 1 of 9
broadband keeps losing connections and intermittent noise on the line
hi can you help my broadband keeps losing connections and i keep getting intermittent noise on my line which gets worse when it rains and my line attenuation keeps changing it was 35 now its any where from 37 to 39 and my house is not moveing about so the is no reson for it to keep changing unless the is a fault my noise margin as all so gone up it was 6db up and 6db down now its 15.9db up and any where from 9db to 12db down when i call customer service all they say is there is noting wrong but to wait 72 hours and it will be fixed and its been like this for over 3 months now i was getting about 9.4mb down befor all this and for what i pay i expect better then this broadband that keeps losing connections and i keeps getting intermittent noise i cannot play live strems a simple google search can take upto 2/3 seconds and sites load slow
12:38:47, 23 Nov. (128700.710000) WAN operating mode is VDSL
12:38:47, 23 Nov. (128700.710000) Last WAN operating mode was VDSL
12:38:46, 23 Nov. (128699.210000) PPP IPCP Receive Configuration ACK
12:38:46, 23 Nov. (128699.200000) PPP IPCP Send Configuration Request
12:38:46, 23 Nov. (128699.200000) PPP IPCP Receive Configuration NAK
12:38:46, 23 Nov. (128699.190000) PPP IPCP Send Configuration ACK
12:38:46, 23 Nov. (128699.190000) PPP IPCP Receive Configuration Request
12:38:46, 23 Nov. (128699.190000) PPP IPCP Send Configuration Request
12:38:44, 23 Nov. (128697.900000) PPPoE is up -​ Down Rate=5517000Kbps, Up Rate=798000Kbps; SNR Margin Down=11.1dB, Up=15.9dB
12:38:44, 23 Nov. (128697.880000) CHAP authentication successful
12:38:44, 23 Nov. (128697.820000) CHAP Receive Challenge
12:38:44, 23 Nov. (128697.820000) Starting CHAP authentication with peer
12:38:44, 23 Nov. (128697.820000) PPP LCP Receive Configuration ACK
12:38:44, 23 Nov. (128697.820000) PPP LCP Send Configuration Request
12:38:44, 23 Nov. (128697.810000) PPP LCP Receive Configuration Reject
12:38:44, 23 Nov. (128697.810000) PPP LCP Send Configuration ACK
12:38:44, 23 Nov. (128697.810000) PPP LCP Receive Configuration Request
12:38:44, 23 Nov. (128697.780000) PPP LCP Send Configuration Request
12:37:34, 23 Nov. (128627.670000) PTM over DSL is up
12:36:51, 23 Nov. (128584.190000) PTM over DSL is down after 242 minutes uptime
12:36:41, 23 Nov. (128574.530000) PPPoE is down after 241 minutes uptime [Disabled]
12:36:36, 23 Nov. (128569.710000) PPP LCP Send Termination Request [User request]
08:35:33, 23 Nov. (114107.080000) WAN operating mode is VDSL
08:35:33, 23 Nov. (114107.080000) Last WAN operating mode was VDSL
08:35:32, 23 Nov. (114105.650000) PPP IPCP Receive Configuration ACK
08:35:32, 23 Nov. (114105.650000) PPP IPCP Send Configuration Request
08:35:32, 23 Nov. (114105.640000) PPP IPCP Receive Configuration NAK
08:35:32, 23 Nov. (114105.640000) PPP IPCP Send Configuration ACK
08:35:32, 23 Nov. (114105.640000) PPP IPCP Receive Configuration Request
08:35:32, 23 Nov. (114105.630000) PPP IPCP Send Configuration Request
08:35:31, 23 Nov. (114104.410000) PPPoE is up -​ Down Rate=5517000Kbps, Up Rate=798000Kbps; SNR Margin Down=10.9dB, Up=16.0dB
08:35:31, 23 Nov. (114104.390000) CHAP authentication successful
08:35:31, 23 Nov. (114104.330000) CHAP Receive Challenge
08:35:31, 23 Nov. (114104.330000) Starting CHAP authentication with peer
08:35:31, 23 Nov. (114104.330000) PPP LCP Receive Configuration ACK
08:35:31, 23 Nov. (114104.320000) PPP LCP Send Configuration Request
08:35:31, 23 Nov. (114104.320000) PPP LCP Receive Configuration Reject
08:35:31, 23 Nov. (114104.320000) PPP LCP Send Configuration ACK
08:35:31, 23 Nov. (114104.320000) PPP LCP Receive Configuration Request
08:34:40, 23 Nov. (114053.930000) PTM over DSL is up
08:34:09, 23 Nov. (114022.860000) PTM over DSL is down after 338 minutes uptime
08:34:09, 23 Nov. (114022.850000) PPPoE is down after 337 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
08:34:06, 23 Nov. (114019.890000) PPP LCP Send Termination Request [User request]
02:56:55, 23 Nov. (93788.270000) WAN operating mode is VDSL
02:56:55, 23 Nov. (93788.270000) Last WAN operating mode was VDSL
02:56:53, 23 Nov. (93786.870000) PPP IPCP Receive Configuration ACK
02:56:53, 23 Nov. (93786.870000) PPP IPCP Send Configuration Request
02:56:53, 23 Nov. (93786.860000) PPP IPCP Receive Configuration NAK
02:56:53, 23 Nov. (93786.860000) PPP IPCP Send Configuration ACK
02:56:53, 23 Nov. (93786.860000) PPP IPCP Receive Configuration Request
02:56:53, 23 Nov. (93786.850000) PPP IPCP Send Configuration Request
02:56:52, 23 Nov. (93785.660000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1118000Kbps; SNR Margin Down=10.4dB, Up=6.4dB
02:56:52, 23 Nov. (93785.650000) CHAP authentication successful
02:56:52, 23 Nov. (93785.600000) CHAP Receive Challenge
02:56:52, 23 Nov. (93785.600000) Starting CHAP authentication with peer
02:56:52, 23 Nov. (93785.600000) PPP LCP Receive Configuration ACK
02:56:52, 23 Nov. (93785.590000) PPP LCP Send Configuration Request
02:56:52, 23 Nov. (93785.590000) PPP LCP Receive Configuration Reject
02:56:52, 23 Nov. (93785.580000) PPP LCP Send Configuration ACK
02:56:52, 23 Nov. (93785.580000) PPP LCP Receive Configuration Request
02:56:52, 23 Nov. (93785.580000) PPP LCP Send Configuration Request
02:56:02, 23 Nov. (93735.830000) PTM over DSL is up
02:55:32, 23 Nov. (93706.140000) PTM over DSL is down after 1545 minutes uptime
02:55:32, 23 Nov. (93706.140000) PPPoE is down after 1544 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
02:55:30, 23 Nov. (93703.280000) PPP LCP Send Termination Request [User request]
01:11:05, 22 Nov. ( 1042.970000) WAN operating mode is VDSL
01:11:05, 22 Nov. ( 1042.970000) Last WAN operating mode was VDSL
01:11:04, 22 Nov. ( 1041.590000) PPP IPCP Receive Configuration ACK
01:11:04, 22 Nov. ( 1041.590000) PPP IPCP Send Configuration Request
01:11:04, 22 Nov. ( 1041.580000) PPP IPCP Receive Configuration NAK
01:11:04, 22 Nov. ( 1041.580000) PPP IPCP Send Configuration ACK
01:11:04, 22 Nov. ( 1041.580000) PPP IPCP Receive Configuration Request
01:11:03, 22 Nov. ( 1041.160000) PPP IPCP Send Configuration Request
01:11:02, 22 Nov. ( 1039.970000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1141000Kbps; SNR Margin Down=10.1dB, Up=6.1dB
01:11:02, 22 Nov. ( 1039.950000) CHAP authentication successful
01:11:02, 22 Nov. ( 1039.900000) CHAP Receive Challenge
01:11:02, 22 Nov. ( 1039.900000) Starting CHAP authentication with peer
01:11:02, 22 Nov. ( 1039.900000) PPP LCP Receive Configuration ACK
01:11:02, 22 Nov. ( 1039.890000) PPP LCP Send Configuration Request
01:11:02, 22 Nov. ( 1039.890000) PPP LCP Receive Configuration Reject
01:11:02, 22 Nov. ( 1039.890000) PPP LCP Send Configuration ACK
01:11:02, 22 Nov. ( 1039.890000) PPP LCP Receive Configuration Request
01:10:12, 22 Nov. ( 990.040000) PTM over DSL is up
01:08:53, 22 Nov. ( 910.460000) PTM over DSL is down after 11 minutes uptime
01:08:53, 22 Nov. ( 910.460000) PPPoE is down after 10 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
01:08:50, 22 Nov. ( 907.580000) PPP LCP Send Termination Request [User request]
01:58:27, 22 Nov. ( 299.690000) WAN operating mode is VDSL
01:58:27, 22 Nov. ( 299.690000) Last WAN operating mode was VDSL
01:58:25, 22 Nov. ( 298.310000) PPP IPCP Receive Configuration ACK
01:58:25, 22 Nov. ( 298.300000) PPP IPCP Send Configuration Request
01:58:25, 22 Nov. ( 298.300000) PPP IPCP Receive Configuration NAK
01:58:25, 22 Nov. ( 298.300000) PPP IPCP Send Configuration ACK
01:58:25, 22 Nov. ( 298.300000) PPP IPCP Receive Configuration Request
01:58:25, 22 Nov. ( 298.290000) PPP IPCP Send Configuration Request
01:58:24, 22 Nov. ( 297.110000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1054000Kbps; SNR Margin Down=9.0dB, Up=6.5dB
01:58:24, 22 Nov. ( 297.100000) CHAP authentication successful
01:58:09, 22 Nov. ( 292.730000) CHAP Receive Challenge
01:58:09, 22 Nov. ( 292.730000) Starting CHAP authentication with peer
01:58:09, 22 Nov. ( 292.730000) PPP LCP Receive Configuration ACK
01:58:09, 22 Nov. ( 292.730000) PPP LCP Send Configuration Request
01:58:09, 22 Nov. ( 292.730000) PPP LCP Receive Configuration Reject
01:58:09, 22 Nov. ( 292.730000) PPP LCP Send Configuration ACK
01:58:09, 22 Nov. ( 292.730000) PPP LCP Receive Configuration Request
01:57:24, 22 Nov. ( 237.440000) PTM over DSL is up
01:55:24, 22 Nov. ( 116.960000) PTM over DSL is down after 0 minutes uptime
01:54:57, 22 Nov. ( 90.430000) PTM over DSL is up
01:54:08, 22 Nov. ( 41.410000) WAN Auto-​sensing running.
00:49:06, 22 Nov. (678348.460000) PTM over DSL is down after 0 minutes uptime
00:48:55, 22 Nov. (678336.600000) PTM over DSL is up
00:47:50, 22 Nov. (678272.250000) PTM over DSL is down after 52 minutes uptime
00:47:50, 22 Nov. (678272.240000) PPPoE is down after 51 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
00:47:47, 22 Nov. (678269.260000) PPP LCP Send Termination Request [User request]
23:55:55, 21 Nov. (675157.300000) WAN operating mode is VDSL
23:55:55, 21 Nov. (675157.300000) Last WAN operating mode was VDSL
23:55:54, 21 Nov. (675155.850000) PPP IPCP Receive Configuration ACK
23:55:54, 21 Nov. (675155.720000) PPP IPCP Send Configuration Request
23:55:54, 21 Nov. (675155.720000) PPP IPCP Receive Configuration NAK
23:55:54, 21 Nov. (675155.720000) PPP IPCP Send Configuration ACK
23:55:54, 21 Nov. (675155.720000) PPP IPCP Receive Configuration Request
23:55:54, 21 Nov. (675155.510000) PPP IPCP Send Configuration Request
23:55:52, 21 Nov. (675154.230000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1122000Kbps; SNR Margin Down=9.9dB, Up=6.3dB
23:55:52, 21 Nov. (675154.220000) CHAP authentication successful
23:55:52, 21 Nov. (675154.030000) CHAP Receive Challenge
23:55:52, 21 Nov. (675154.030000) Starting CHAP authentication with peer
23:55:52, 21 Nov. (675154.030000) PPP LCP Receive Configuration ACK
23:55:52, 21 Nov. (675154.030000) PPP LCP Send Configuration Request
23:55:52, 21 Nov. (675154.030000) PPP LCP Receive Configuration Reject
23:55:52, 21 Nov. (675154.020000) PPP LCP Send Configuration ACK
23:55:52, 21 Nov. (675154.020000) PPP LCP Receive Configuration Request
23:55:52, 21 Nov. (675154.020000) PPP LCP Send Configuration Request
23:55:01, 21 Nov. (675103.350000) PTM over DSL is up
23:54:28, 21 Nov. (675070.320000) PTM over DSL is down after 5121 minutes uptime
23:54:28, 21 Nov. (675070.320000) PPPoE is down after 5120 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
23:54:25, 21 Nov. (675067.200000) PPP LCP Send Termination Request [User request]
10:33:47, 18 Nov. (367835.440000) WAN operating mode is VDSL
10:33:47, 18 Nov. (367835.440000) Last WAN operating mode was VDSL
10:33:46, 18 Nov. (367834.030000) PPP IPCP Receive Configuration ACK
10:33:46, 18 Nov. (367834.030000) PPP IPCP Send Configuration Request
10:33:46, 18 Nov. (367834.020000) PPP IPCP Receive Configuration NAK
10:33:46, 18 Nov. (367834.020000) PPP IPCP Send Configuration ACK
10:33:46, 18 Nov. (367834.020000) PPP IPCP Receive Configuration Request
10:33:46, 18 Nov. (367834.020000) PPP IPCP Send Configuration Request
10:33:45, 18 Nov. (367832.800000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1126000Kbps; SNR Margin Down=11.1dB, Up=6.1dB
10:33:45, 18 Nov. (367832.790000) CHAP authentication successful
10:33:45, 18 Nov. (367832.730000) CHAP Receive Challenge
10:33:45, 18 Nov. (367832.730000) Starting CHAP authentication with peer
10:33:45, 18 Nov. (367832.730000) PPP LCP Receive Configuration ACK
10:33:45, 18 Nov. (367832.720000) PPP LCP Send Configuration Request
10:33:45, 18 Nov. (367832.720000) PPP LCP Receive Configuration Reject
10:33:45, 18 Nov. (367832.720000) PPP LCP Send Configuration ACK
10:33:45, 18 Nov. (367832.720000) PPP LCP Receive Configuration Request
10:32:54, 18 Nov. (367782.250000) PTM over DSL is up
10:32:24, 18 Nov. (367752.510000) PTM over DSL is down after 2121 minutes uptime
10:32:24, 18 Nov. (367752.500000) PPPoE is down after 2120 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
10:32:21, 18 Nov. (367749.470000) PPP LCP Send Termination Request [User request]
23:11:41, 16 Nov. (240514.120000) WAN operating mode is VDSL
23:11:41, 16 Nov. (240514.120000) Last WAN operating mode was VDSL
23:11:40, 16 Nov. (240512.700000) PPP IPCP Receive Configuration ACK
23:11:40, 16 Nov. (240512.690000) PPP IPCP Send Configuration Request
23:11:40, 16 Nov. (240512.680000) PPP IPCP Receive Configuration NAK
23:11:40, 16 Nov. (240512.680000) PPP IPCP Send Configuration ACK
23:11:40, 16 Nov. (240512.680000) PPP IPCP Receive Configuration Request
23:11:40, 16 Nov. (240512.680000) PPP IPCP Send Configuration Request
23:11:39, 16 Nov. (240511.450000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1114000Kbps; SNR Margin Down=9.5dB, Up=6.0dB
23:11:39, 16 Nov. (240511.440000) CHAP authentication successful
23:11:39, 16 Nov. (240511.380000) CHAP Receive Challenge
23:11:39, 16 Nov. (240511.380000) Starting CHAP authentication with peer
23:11:39, 16 Nov. (240511.380000) PPP LCP Receive Configuration ACK
23:11:39, 16 Nov. (240511.380000) PPP LCP Send Configuration Request
23:11:39, 16 Nov. (240511.380000) PPP LCP Receive Configuration Reject
23:11:39, 16 Nov. (240511.370000) PPP LCP Send Configuration ACK
23:11:39, 16 Nov. (240511.370000) PPP LCP Receive Configuration Request
23:11:39, 16 Nov. (240511.370000) PPP LCP Send Configuration Request
23:10:49, 16 Nov. (240461.360000) PTM over DSL is up
23:08:02, 16 Nov. (240294.860000) PTM over DSL is down after 160 minutes uptime
23:08:02, 16 Nov. (240294.860000) PPPoE is down after 159 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
23:07:59, 16 Nov. (240291.910000) PPP LCP Send Termination Request [User request]
20:28:30, 16 Nov. (230723.090000) WAN operating mode is VDSL
20:28:30, 16 Nov. (230723.090000) Last WAN operating mode was VDSL
20:28:29, 16 Nov. (230721.640000) PPP IPCP Receive Configuration ACK
20:28:29, 16 Nov. (230721.630000) PPP IPCP Send Configuration Request
20:28:29, 16 Nov. (230721.630000) PPP IPCP Receive Configuration NAK
20:28:29, 16 Nov. (230721.620000) PPP IPCP Send Configuration ACK
20:28:29, 16 Nov. (230721.620000) PPP IPCP Receive Configuration Request
20:28:29, 16 Nov. (230721.620000) PPP IPCP Send Configuration Request
20:28:28, 16 Nov. (230720.380000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=873000Kbps; SNR Margin Down=9.4dB, Up=13.2dB
20:28:28, 16 Nov. (230720.370000) CHAP authentication successful
20:28:28, 16 Nov. (230720.310000) CHAP Receive Challenge
20:28:28, 16 Nov. (230720.310000) Starting CHAP authentication with peer
20:28:28, 16 Nov. (230720.310000) PPP LCP Receive Configuration ACK
20:28:28, 16 Nov. (230720.300000) PPP LCP Send Configuration Request
20:28:28, 16 Nov. (230720.300000) PPP LCP Receive Configuration Reject
20:28:28, 16 Nov. (230720.290000) PPP LCP Send Configuration ACK
20:28:28, 16 Nov. (230720.290000) PPP LCP Receive Configuration Request
20:28:28, 16 Nov. (230720.290000) PPP LCP Send Configuration Request
20:27:37, 16 Nov. (230669.490000) PTM over DSL is up
20:27:07, 16 Nov. (230639.750000) PTM over DSL is down after 3842 minutes uptime
20:27:07, 16 Nov. (230639.740000) PPPoE is down after 3841 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
20:27:04, 16 Nov. (230636.700000) PPP LCP Send Termination Request [User request]
05:25:10, 14 Nov. ( 144.080000) WAN operating mode is VDSL
05:25:10, 14 Nov. ( 144.080000) Last WAN operating mode was VDSL
05:25:09, 14 Nov. ( 142.720000) PPP IPCP Receive Configuration ACK
05:25:09, 14 Nov. ( 142.600000) PPP IPCP Send Configuration Request
05:25:09, 14 Nov. ( 142.600000) PPP IPCP Receive Configuration NAK
05:25:09, 14 Nov. ( 142.600000) PPP IPCP Send Configuration ACK
05:25:09, 14 Nov. ( 142.600000) PPP IPCP Receive Configuration Request
05:25:08, 14 Nov. ( 142.400000) PPP IPCP Send Configuration Request
05:25:07, 14 Nov. ( 141.230000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1122000Kbps; SNR Margin Down=10.3dB, Up=6.1dB
05:25:07, 14 Nov. ( 141.220000) CHAP authentication successful
05:25:07, 14 Nov. ( 141.100000) CHAP Receive Challenge
05:25:07, 14 Nov. ( 141.100000) Starting CHAP authentication with peer
05:25:07, 14 Nov. ( 141.100000) PPP LCP Receive Configuration ACK
05:25:07, 14 Nov. ( 140.980000) PPP LCP Send Configuration Request
05:25:07, 14 Nov. ( 140.980000) PPP LCP Receive Configuration Reject
05:25:07, 14 Nov. ( 140.860000) PPP LCP Send Configuration ACK
05:25:07, 14 Nov. ( 140.860000) PPP LCP Receive Configuration Request
05:25:07, 14 Nov. ( 140.860000) PPP LCP Send Configuration Request
05:24:15, 14 Nov. ( 89.030000) PTM over DSL is up
05:23:24, 14 Nov. ( 38.440000) WAN Auto-​sensing running.
04:22:31, 14 Nov. (1211085.120000) PPP LCP Send Termination Request [User request]
21:56:44, 13 Nov. (1187938.850000) WAN operating mode is VDSL
21:56:44, 13 Nov. (1187938.840000) Last WAN operating mode was VDSL
21:56:42, 13 Nov. (1187937.410000) PPP IPCP Receive Configuration ACK
21:56:42, 13 Nov. (1187937.400000) PPP IPCP Send Configuration Request
21:56:42, 13 Nov. (1187937.400000) PPP IPCP Receive Configuration NAK
21:56:42, 13 Nov. (1187937.390000) PPP IPCP Send Configuration ACK
21:56:42, 13 Nov. (1187937.390000) PPP IPCP Receive Configuration Request
21:56:42, 13 Nov. (1187937.390000) PPP IPCP Send Configuration Request
21:56:41, 13 Nov. (1187936.160000) PPPoE is up -​ Down Rate=5792000Kbps, Up Rate=1122000Kbps; SNR Margin Down=10.3dB, Up=6.4dB
21:56:41, 13 Nov. (1187936.140000) CHAP authentication successful
21:56:41, 13 Nov. (1187936.070000) CHAP Receive Challenge
21:56:41, 13 Nov. (1187936.070000) Starting CHAP authentication with peer
21:56:41, 13 Nov. (1187936.070000) PPP LCP Receive Configuration ACK
21:56:41, 13 Nov. (1187936.060000) PPP LCP Send Configuration Request
21:56:41, 13 Nov. (1187936.060000) PPP LCP Receive Configuration Reject
21:56:41, 13 Nov. (1187936.060000) PPP LCP Send Configuration ACK
21:56:41, 13 Nov. (1187936.060000) PPP LCP Receive Configuration Request
21:55:51, 13 Nov. (1187885.910000) PTM over DSL is up
21:55:21, 13 Nov. (1187855.740000) PTM over DSL is down after 11753 minutes uptime
21:55:21, 13 Nov. (1187855.740000) PPPoE is down after 11752 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
21:55:18, 13 Nov. (1187852.670000) PPP LCP Send Termination Request [User request]
8 REPLIES 8
Message 2 of 9
Re: broadband keeps losing connections and intermittent noise on the line
Untitled00.pngUntitled11.jpgUntitled22.jpgUntitled33.jpgUntitled33.jpgUntitled44.pngUntitled55.jpgUntitled66.jpgUntitled77.jpg2355Untitled.jpg
Message 3 of 9
If you still have problems when connected to the test socket behind the removable faceplate on the master socket, contact customer services and insist on an engineer visit. Do not be fobbed off with the 72 hours cobblers.
Message 4 of 9
Message 5 of 9
Remove bottom faceplate and connect to the test socket behind using a new filter. Also make a quiet line test with  a corded phone, dial 17070 and select quiet line test. Line should be completely silent. If noisy, report to 151 as a phone fault noisy line, do not mention broadband.
Sage
Message 6 of 9
Now that we are heading towards winter then line attenuation will fluctuated the same as the conductivity of copper varies depending on temperature.
The temperature differences over 24hrs in winter are markedly different to summer.
Message 7 of 9
it does not matter whether it is winter or summer my line attenuation is all ways changing i have been with bt 3 year now and for the first 2  1/2 Years it was rock solid at 35db for all that time and it never changed and i no this because i like to check the routers helpdesk every day or every other day
Message 8 of 9
Have you tried the quiet line test and connected the router to the test socket? You need to do that to ensure the fault is not in your internal wiring.
Message 9 of 9
i am going to get a corded phone tomorrow to try it and a new filter if i can get one as i never got any with my router when it was sent
