Message 1 of 4
broadband problem - fixed?
I reported a problem  with our broadband  dropping out several days ago.
Last  night we had no dropouts, but a speed test shows about half of the speeds we used to get.
Looking on MyBT today, I see that the fault has been closed , and there is a message stating "Thanks for letting us know the fault has now been fixed"
I have not told BT anything?
Is there any way I can get confirmation that a fault has indeed been found/fixed, and maybe even what it was?
3 REPLIES 3
Message 2 of 4
Re: broadband problem - fixed?
there is nothing other than what you have found advising fault fixed
Message 3 of 4
Thanks for the quick response!
Would have been nice to know what was fixed, particularly as I have spent quite some time swapping out cables/routers etc and am currently connecting to the test socket. Knowing it was at the BT end would mean I could just restore everything at my end back to its original state.
If a problem was found on the BT side, the loss of speed is probably related. Perhaps this will increate in time.
Thanks again!
Message 4 of 4
if the engineer did not enter your home then problem not on your side of the test socket
