Hi,
My BB upto a few days ago was running about 4-5mbps, which I was quite happy with - it could be upto 7.1 but I reckon i'll never get it.
But over the last 2 days the speed has gone - completely even posting this has been a process!!!
results from the speed checker enclosed
Download speedachieved during the test was - 806 Kbps
For your connection, the acceptable range of speeds is 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Download speedachieved during the test was - 225 Kbps
For your connection, the acceptable range of speeds is 576-600 Kbps.
Assured Rate IP profile on your line is - 600 Kbps
Line state | Connected |
Connection time | 2 days, 5:28:09 |
Downstream | 8,128 Kbps |
Upstream | 448 Kbps |
VPI/VCI | 0/38 |
Type | PPPoA |
Modulation | ITU-T G.992.1 |
Latency type | Fast |
Noise margin (Down/Up) | 16.9 dB / 19.0 dB |
Line attenuation (Down/Up) | 2.0 dB / 3.0 dB |
Output power (Down/Up) | 7.8 dBm / 11.9 dBm |
sure, they are a pain to do though because its so slow.
I have had notification from BT that the fault on my line will be fixed by the 15th Feb........
