john46
Message 41 of 47
Re: broadband speed limited to 1mb
you need to contact the mod who was helping you
imjolly
Message 42 of 47
can you post the 2 lines of stats from the logs please
are you able to run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
AandG
Message 43 of 47
Hi there, is this what you mean? -
Download speedachieved during the test was - 1.96 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :2.66 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
imjolly
Message 44 of 47
the 2 lines like you did in message 28
AandG
Message 45 of 47
13:49:49, 10 Aug. ( 74.250000) DSL noise margin: 17.00 dB upstream, 6.10 dB downstream
13:49:49, 10 Aug. ( 74.180000) DSL line rate: 448 Kbps upstream, 2656 Kbps downstream
imjolly
Message 46 of 47
you stats look ok and connection stable since 10/8 with speed 2656kbps and correct profile of 2mb and good download speed for profile
AandG
Message 47 of 47
Todays speed test results -
Download - 0.92Mbps
Upload - 0.07Mbps
Ping - 0.00Mbps
Why this massive variation, nothing here has changed?
