Moderator
Moderator
Message 11 of 64
Re: broadband speed very slow
Hi bosyk,
Thanks for posting and welcome to the forum.
Sorry for the problems you're having with your broadband speed.  Send over your details and we'll check this out from here.  You'll see the link to get in touch in my profile under the section "about me".  You'll find it by clicking on my username.
Cheers
Robbie
Message 12 of 64
Hi thanks for anwers
RobbieMac I cannot find the link
i have BT hub 2.0 , i just bored from my friend right now.
i post for u some info ,
speed -> http://www.speedtest.net/my-result/3476258664
IP Profile 7150. When i going here to check BT Wholesale Broadband Performance Test
i getting error for now , before was working twice
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 01:41:10
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)14.2 dB / 28.0 dB
Line attenuation (Down/Up)14.5 dB / 7.5 dB
Output power (Down/Up)16.0 dBm / 2.0 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)3 / 0
CRC Errors (Down/Up)2 / 0
HEC Errors (Down/Up)6 / 0
Error Seconds (Local/Remote)
2 / 0
Message 13 of 64
your stats are good with max connection speed for adslmax.  the problem is exchnage congestion which need wholesale to upgrade the virtual path.  once that's done your download speed will return to normal - just need to wait and hopefully the mods will be able to speed things along or at very least keep you up to date on fix timescale
Message 14 of 64
Please keep trying the BT speedtest as it is the only one accepted for speed problems
Message 15 of 64
@john46
on same exchnage as gt900uk and suffering the same exchange congestion so same VP.  btspeedtester which has already been done will just confirm the slow/poor download speed.  just need to get wholesale moving as that is 2 customers posting with same problem on same exchange
Message 16 of 64
hi john problem is: Before was working fine , when i was spoke with someone on phone, right now i just getting this
Message 17 of 64
just suggesting the speed test will give more evidence to the mods for wholesale
Moderator
Moderator
Message 18 of 64
Hey bosyk,
Whoops, my mistake.
Check it there now and you should see the link.
Cheers
Robbie
Message 19 of 64
I going to work now , here the pic. Robi I gonna back from work and send to you
i just dont get it wht my  ID profile is diffrent now , should be 7150 . Cheers anyway
Message 20 of 64
Your router has reset and your connection speed has dropped from 8mb to 4.7mb hence the lower profile
