bosyk
Message 1 of 64
broadband speed very slow
Hi I have very slow broadband speed. i dont use the bt hub.
But here is the info from my switch
Download speed 1,02
Upload speed 0,32
Ping 49.50
Tested on -> http://speedtest.btwholesale.com/
D-link DLS-2640R
ADSL Statistics
Mode:G.DMT
Type:ANNEX_A
Status:Showtime
 DownstreamUpstream
Rate (Kbps):8096 kbps448 kbps
SNR Margin (dB):10.523.0
Attenuation (dB):17.08.5
Output Power (dBm):17.512.0
Super Frames:2830928309
RS Correctable Errors:00
RS Uncorrectable Errors:00
HEC Errors:00
Total Cells:3364184238
Data Cells:40486546954
Bit Errors:00
ADSL Modulation :G.DMT
Cable Status :ADSL Link Up
Virtual Circuit :
Connection Type :PPPoE/PPPoA
Network Status :Connected
Connection Up Time :0:00:06:45
Downstream Line Rate :8096 kbps
Upstream Line Rate :448 kbps
63 REPLIES 63
imjolly
Message 2 of 64
Re: broadband speed very slow
you need to run btspeedtester with wired conenction and when first test completes then run diagnostic test and post results
bosyk
Message 3 of 64
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 0.96 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
imjolly
Message 4 of 64
sorry but you need to keep trying to get diagnostic test to run
are there any exchange problems http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
bosyk
Message 5 of 64
Hi i can change for bt hub i take from my friend again if that can help you
Results: Dunoon
Code:WSDUN
County:Strathclyde
Enabled:06 Apr 2005
Market:2
Mkt2014:A
Colour: Red20CN VP capacity at this exchange is currently showing as Red.
Click here for further details
Colour: RedBT have not advised a planned date for WBC on 21CN
Colour: UnknownYou can view recent Service Outages for this exchange here
Colour: UnknownBT have published Max DSL upgrade information for this exchange
john46
Message 6 of 64
you are suffering from exchange congestion all you can do is wait for BT Wholesale to carry out a virtual path upgrade
imjolly
Message 7 of 64
That shows a problem with the VP which is the reason for your good connection speed but very poor download speed
you need mod help and they will post a contact us link when they read this
this is another customer on same exchnage with same problem  https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/Broadband-Speed-Issues/td-p/1187390
phone faults
live chat
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
bosyk
Message 8 of 64
 20CN virtual paths: Red
BT is reporting that some of the 20CN virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: 25 Apr 14
Record last updated: 31 Jan 14
i should be fixed by now ? or not ?
imjolly
Message 9 of 64
you need mod help as does another customer on same exchnage https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/Broadband-Speed-Issues/td-p/1187390
mods will help
john46
Message 10 of 64
the fix date given is an estimate major network faults or other problems can cause routine maintenance projects to be delayed
