imjolly
Message 31 of 64
Re: broadband speed very slow
Please update after mods get in contact
john46
Message 32 of 64
just wait for the mods to contact you and take no notice of the help line  they will contact you personally by email or phone and they are UK Based they normaal reply wihin 3/5 working days  of you sending the contact form to them
bosyk
Message 33 of 64
Hi
I back today from work at get speed 3.2mb/s
For now is :
Is better . Sorry Robbie to not pick the phone but i was in work
imjolly
Message 34 of 64
can you post your router stats please as looks like btspeedtester still totally wrong
bosyk
Message 35 of 64
yesterday i spoke someone from Bt ask me to restart the hub. Someone from exchange change the ID profile , They said to us the can give us speed from 2.5 -5 and they need to change ID profile, becouse we are connected to exachge nr 9 , and this exchange is support speed from 2.5 -5
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 16:31:36
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeFast
Noise margin (Down/Up)13.8 dB / 25.0 dB
Line attenuation (Down/Up)14.5 dB / 7.5 dB
Output power (Down/Up)12.4 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)15 / 0
HEC Errors (Down/Up)42 / 0
Error Seconds (Local/Remote)15 / 0
imjolly
Message 36 of 64
your IP profile is completely wrong for your conenction speed and you need to wait on mods sorting it - your profile should be 7.15mb not 4mb
bosyk
Message 37 of 64
@ imjolly
someone from exchange change from 7.15 to 4mb. They tell us is not support more,
speed again 0.97 😄
imjolly
Message 38 of 64
sorry but with your connection speed your profile should be 7.15mb see here
check profile
bosyk
Message 39 of 64
imjolly
So why someone change it?? in first page i have 7.15 after 4mb
imjolly
Message 40 of 64
I don't think anyone changed it.  you probably hada a drop in connection or a manual reset or possibly both which resulted in a drop in your connection speed which then would almost immediately drop your profile to correspond to your lower connection speed.  when your router reset again the speed came back to 8128 but your profile would normally take 3/5 days conencted 24/7 to recover to 7.15mb profile.
your btspeedtester results still show a conenction speed of 4.7mb and the correct profile for that speed but your actual speed is 8128 hence there is a problem with your profile and you need mods and/or wholesale to fix it
