bosyk
Message 41 of 64
Re: broadband speed very slow
Someone from wholesale phone me and inform me the Id profile is change from 7.15 to 4 i dont know way . I was spoke with some lady and she said to me the exchagne was im connected is just support 2.5 -5 . I got msg on my phone . "Hello BT here. We have made a profile change on your line, and this take effect in the next 48h-72h. "
imjolly
Message 42 of 64
is that not to correct your profile to 7.15mb which is the correct figure for your current connection speed - as you can see from the profile check link I posted
bosyk
Message 43 of 64
so what i should do now?
imjolly
Message 44 of 64
as you seem unsure as to what is happening I have asked mods to clarify
bosyk
Message 45 of 64
thank men
PaddyB
Moderator
Moderator
Message 46 of 64
Hi Bosyk,
I can see that Robbie dropped you an email this morning. A profile reset was done this morning and this should increase your profile to 7150 Kbps, which would be in line with your sync speed of 8128 Kbps.
If you could test you speed again tomorrow to see if the profile has increase, if you don't see an improvement drop Robbie a reply and he will get this investigated.
PaddyB
bosyk
Message 47 of 64
ok i will do. thanks again
imjolly
Message 48 of 64
please repost you btspeedtester diagnostic results after mods get profile reset to 7.15mb
bosyk
Message 49 of 64
Hi
I wait 2 days and My profile is not change
Should i restart the hub ??
Connection Information
Line stateConnected
Connection time2 days, 19:25:04
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeFast
Noise margin (Down/Up)13.8 dB / 25.0 dB
Line attenuation (Down/Up)14.5 dB / 7.5 dB
Output power (Down/Up)12.4 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)74 / 0
HEC Errors (Down/Up)172 / 0
Error Seconds (Local/Remote)71 / 0
imjolly
Message 50 of 64
from btspeedtester results your profile still has not been reset hence why no change.  there is nothing you can do as mods are on your case
