dorothy
Newbie
Message 1 of 3
broadband usage
Couple of weeks ago I was able to track my broadband usage on my online account. It projected if usage was within range of allowance. In a bar chart form coloured green amber red I think. Can't find it anymore.  Can anyone help? Maybe I'm looking for it in the wrong place.  Thanks
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: broadband usage
Hi dorothy and welcome
Have a read of the following thread - http://community.bt.com/t5/BB-Speed-Connection-Issues/Is-there-a-way-to-check-how-much-I-ve-download...
(Note the images on the above link)
Let us know if it helps
-+-No longer a forum member-+-
Distinguished Guru
Message 3 of 3
Re: broadband usage
Hi Dorothy. Welcome to the forums.
Have a look at my shortcuts (http://www.andyweb.co.uk/shortcuts), options 14d-14g. These are slighly quicker ways to access the online meter. Hopefully one will work for you.
Typically you go to www.bt.com, and click on MyBT. From there login with your Broadband associated username, and click on My Services. Click the green "b" and then View your broadband usage.
When you get to the online meter (which should be similar to my shortcuts option 14g - but with your unique token number at the end) - bookmark that page. When you need to look again, go to your bookmark and it should either request your login details - after input will take you directly to the meter, or if you are already logged in - it will show the meter.
